Fuel Pump Hatch, and Suspension Question
In the rear you only need to replace the bumpstops if they are eroded or broken away. The front you should be fine for Bilsteins as you reuse the stock dust boot that has the bumpstop in it. Konis have a new one included. I would definitely spring for the Koni SAs for a V8...
You will want to get some anti-seaze lube for the threads -- apply a light coating.
Then some good tunes and good beer. Someone to cook some good BBQ to be ready when you need a break.
Take your time, the fronts are an involved process. Rears are easy. I assume you have stock springs? If so, you should be good.
@ Androzer- You can do it the traditional (right) way, by dropping the tank and removing the pump there, but this way is a lot more convenient, and as people have a lot of trouble with the newer pumps sometimes, I think worth it.
