Fuel Pump Hatch, and Suspension Question
Old Feb 19, 2012 | 12:33 AM
libertyforall1776's Avatar
In the rear you only need to replace the bumpstops if they are eroded or broken away. The front you should be fine for Bilsteins as you reuse the stock dust boot that has the bumpstop in it. Konis have a new one included. I would definitely spring for the Koni SAs for a V8...
You will want to get some anti-seaze lube for the threads -- apply a light coating.
Then some good tunes and good beer. Someone to cook some good BBQ to be ready when you need a break.
Take your time, the fronts are an involved process. Rears are easy. I assume you have stock springs? If so, you should be good.
Old Feb 19, 2012 | 09:54 AM
androzer's Avatar
all F-bodies has this issue of fuel pump? I mean needs this kind of swap?
late 4th gen also?
Old Feb 19, 2012 | 03:19 PM
Javs_is_fat's Avatar
Too late now but you were not supposed to cut those ridges, they give the body structural support. If you closed it up well it shouldn't be a big deal though.
Old Feb 19, 2012 | 03:36 PM
Mikey.'s Avatar
I'm really not worried about it. If it was meant for support they should have used something a lot thicker. I've seen countless people do the same. Plus the extra access it gives to the lines is worth it. But the material I used to cover it should be enough.
@ Androzer- You can do it the traditional (right) way, by dropping the tank and removing the pump there, but this way is a lot more convenient, and as people have a lot of trouble with the newer pumps sometimes, I think worth it.
craby
Jun 1, 2012 12:13 PM
rachel11
Apr 3, 2012 07:26 AM
DashingDaryl
Mar 12, 2012 09:41 PM
sebi1990
Feb 1, 2011 12:34 PM
camarofreak1990
Jun 26, 2009 12:48 AM
