Anyone do the Fuel Pump Access Hatch?
Old Mar 9, 2012 | 12:30 PM
DashingDaryl's Avatar
Default Anyone do the Fuel Pump Access Hatch?
I was thinking of buying a Firebird with a bad fuel pump. I know the easiest way to change the pump is through an access hatch. The instructions look pretty straight forward, but I was wondering if anyone has ever done it, and what are their thoughts, memories and tips.
Old Mar 9, 2012 | 01:18 PM
Thoughts: Simple, easy, Glad I did it because the cheap airtec pump failed a month after it was installed. 2nd Replacment took 1/2 an hour.
Old Mar 9, 2012 | 04:15 PM
libertyforall1776's Avatar
I wonder if anyone has done a true sealed hinged access door, as opposed to a riveted and moisture/vapor sealed door. Not likely as it would be a pain in the butt, but could be a nice kit some enterprising entrepreneur could sell...
Old Mar 9, 2012 | 05:20 PM
I made the hatch pump replacement attempt on my 91 (later found 3rd gens don't have disconnects like the 4th gens). I made a cover and used the silicone/screw attachment method. With a screw gun, you could get it back off in a minute, but on average shouldn't be necessary to do again unless you put in a cheapo pump.
Old Mar 9, 2012 | 07:56 PM
Javs_is_fat's Avatar
I did it, as much as I don't like chopping up my Camaro's body. I really didn't wanna drop my tank though so I did the hatch method. It's not hard just make your cuts straight and seal it up properly.
Old Mar 12, 2012 | 12:52 PM
Thanks guys, I appreciate your input
Old Mar 12, 2012 | 05:04 PM
saltflat's Avatar
Default sender access port
2002 convertible p0466 code. does anyone have a picture for the exact location for cutting the access port?
Old Mar 12, 2012 | 09:41 PM
found in the how to and faq sticky at the top of this section, https://camaroforums.com/forum/93-02...rt-here-38462/ lots of good info there.
HYDRA_SH0CK
Aug 13, 2010 12:32 AM
coopdc78
Jun 9, 2010 12:43 PM
bluovlh8er
Nov 15, 2007 05:27 PM
libertyforall1776
Oct 17, 2007 12:22 AM
