Fuel injector questions
Old Mar 21, 2013 | 12:09 PM
vanquishfist's Avatar
Default Fuel injector questions
I've got gas in my vacuum line, so I will be changing my fuel pressure regulator soon, which means the fuel rail and injectors need to come off.
My questions are: Should I just replace the two o-rings on the injectors, or should I get the whole seal kit with the pintle cap and spacer? Also, is there a way I can clean and test the injectors, or do I have to take them somewhere?
Thanks.
Old Mar 21, 2013 | 12:46 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I would go ahead and replace all of the o rings, since they are cheap and you are already there. and you would have to take them somewhere to get the tested. I wouldnt worry about that
Old Mar 21, 2013 | 02:09 PM
slick's camaro's Avatar
You can soak them in some seafoam
Old Mar 21, 2013 | 05:10 PM
I do have some seafoam already. So just soak the whole injector in some seafoam? The figured it might not be a bad idea to get the injectors tested since I just hit 150k miles recently.
Does the spacer and that pintle cap usually go bad? And does it matter what brand o-rings I get?
Old Mar 21, 2013 | 05:15 PM
look around and see if you have an injector shop close. doesnt take long to get them cleaned and flow tested. cost like 10 or 15 bucks each. sent mine ups to a place called doctor injector took three days to get em back.
Old Mar 21, 2013 | 10:12 PM
Thanks craby. I'll have to ask around.
So what do you think about the o-rings? OEM, generic, full kit or just the o-rings?
Old Mar 22, 2013 | 05:40 AM
agree with socom get the o rings, i got new o rings with the clean and flow test
Old Apr 3, 2013 | 08:08 PM
I have another question for you Craby.
I seem to remember reading a thread where you mentioned you can check if an injector is leaking by pressuring the system with the injectors out and a piece of cardboard under them. Can you get them out without disconnecting all the fuel lines, vacuum hoses, unplugging the injectors and other misc. components? Or do you have to take it apart then reconnect to check for leaks? How can I safely do this?
Thanks
Old Apr 4, 2013 | 12:11 AM
i just pulled the injector rack up with everything still connected the last time i did it. by then i had it down pat. first time i took it all apart and put it back together.
Kendagenius
Feb 5, 2017 12:23 PM
Z28Camaro98
LS Series Tech
Mar 27, 2013 07:19 PM
princesid84
Dec 10, 2012 09:28 PM
r6rider
Dec 7, 2009 02:20 PM
johnson3034
May 25, 2007 09:35 PM
