front tire size on 02 camaro ss
Old Aug 27, 2007 | 12:35 PM
speedygolf's Avatar
Default front tire size on 02 camaro ss
My GF has a 2002 camaro ss with 275-45-17 all the way around. Its getting time to replace the factory tires. I want to put "skinner" tires on the front. Probably like a 245. My hopes are it will prevent the car from darting all over "smooth" NJ highways. Car has factory ss wheels I believe 9.5" wide.
Thoughts about this? Recommended tire sizes??
Anything else that can help this car from tramlining all over the place.
Thanks
Dave
Old Aug 27, 2007 | 12:39 PM
Lee Willis's Avatar
Default RE: front tire size on 02 camaro ss
It might make it worse, you can't be certain. I ran 275s all around back when our Camaro was only lightly modified and it never seemed to dart orshift that much even on rather bad roads or when driving over siping, pavementseams, etc.
Old Aug 27, 2007 | 05:47 PM
94Z28SHAKER's Avatar
yea, smaller (skinnier) low profiletires actually make it worse, it might help to get a fatter tire if it can fit, like 275/55/17
Old Aug 29, 2007 | 10:20 PM
nickdotcom's Avatar
just keep the same size all around, it shouldn't be darting around. maybe get the alignment checked out
275-40-17 will work great
plus if you use the same size you can get them rotated and they will last much longer
Old Sep 1, 2007 | 09:55 PM
CamaroSS2045's Avatar
My 98 SS "darts around", it usually means I need to check the tire pressure. I've only notice it with low profile tires.
67 engine revvin
Oct 18, 2016 01:48 PM
Slick110
Dec 16, 2015 06:47 PM
1995Camaro
Feb 26, 2011 06:48 PM
Gen2-454
70-81 V8 Tech
Jan 20, 2011 05:42 PM
b2then
70-81 V8 Tech
Sep 3, 2009 05:41 PM
