DAMN IT. Coolant hose popped off and intake sucked coolant in.
Old 12-05-2010, 05:21 PM
ChevyManCam's Avatar
im guessing blown head, if your pouring coolant and it seems endless and never fills, your coolant is making its way in between the head, into whats called a water jacket, unless its going on the ground which I doubt because you have not mentioned it was leaking on the ground
  #22
Old 12-05-2010, 05:35 PM
AnalyzeFaith's Avatar
It isnt going to the ground at all. Does this also mix with the oil? Also, why does my intake spit white gunk out? My intake sucked a lot of coolant in and it smokes like crazy out of the intake. What can I do about that?
  #23
garner's Avatar
Try a new filter and see if that solves any of the smoke
  #24
Old 12-05-2010, 05:40 PM
Its all in the intake system already, it sucked A LOT of coolant in.
  #25
Old 12-05-2010, 05:54 PM
Your Coolant is leaking into the lower end, into the crank, mixing with your oil, hence when you start the car, pressure is sucking the oil/water in to the piston chambers thus pushing it back into the intake out of the TBI base. Wild guess but sounds logical at least
blackbeauty1995
12-22-2013 08:32 PM
carlocamaroVA
02-05-2013 02:09 PM
Camaro3800V6
08-17-2011 03:47 PM
hooknladder
04-15-2011 08:50 PM
Ganon00
05-01-2009 08:33 PM
Quick Reply: DAMN IT. Coolant hose popped off and intake sucked coolant in.
