from CT 95 camaro
Old May 16, 2014 | 08:35 PM
2Z's's Avatar
Originally Posted by warmeck
i went and saw the $6000 one sounds nice shifts good, i have to go see the $3200 one and compare, i do want to make engine upgrades/body kit so i will be spending more money on it. hmmmmm this guy with the $6000 is kinda pricey and the difference is $2800 dollars. any other opinions?
Ill give you another suggestion. Something I love to see when buying a used car is a record of maintenance...maybe a folder of reciepts, or at the very least a written log book of oil changes and/or major repairs that have been done. Incidentially, when I sell a car, I ALWAYS include the folder of recipts. Ive had guys tell me it was the deciding factor in purchasing my car over another.
Old May 16, 2014 | 10:23 PM
warmeck's Avatar
thanks im going to go see the 3200 car tomorrow and ill ask. the 6000 guy said he had no paperwork for it so we will see. Thanks for the help time to get me a camaro!
Old May 17, 2014 | 08:57 AM
carmel73's Avatar
let us know how it goes warmeck
Old May 19, 2014 | 08:16 PM
warmeck's Avatar
Question
so the 3200 guy is saying 3000 and it needs a valve cover gasket? the guy says the valve cover is leaking. Is this worth what he is saying? is this a hard job to do? i saw a step by step guide on the forums but still need an idea of the work/labor. thanks! also could there be any other problems with the car that could cause this?
Old May 19, 2014 | 09:22 PM
2Z's's Avatar
So, as far as the valve cover gaskets go...no too bad of a job really. A little time consuming if youve never done the job before...
HOWEVER.... my guess would be the "valve cover gasket leak" is actually an intake manifold leaking some oil from the rear. Its pretty common on LT engines with some miles on them. Not a particularly hard job either, but more involved than valve cover gaskets alone. You can do it yourself and fairly inexpensive as far as parts....
Does the seller have reiepts or maintenance records of any kind?
Old May 19, 2014 | 10:16 PM
^^^ agree, valve cover gaskets leaking is pretty rare. intake at front and rear is common. did it look like the oil was coming from the top of the passenger side valve cover? that would be blow by and a indicator the motor is not happy.
Old May 19, 2014 | 11:30 PM
warmeck's Avatar
I will ask him about recipets tomorrow and he said its that because he just did the "intake manifold gaskets". so i should look for it leaking oil near the passenger side indicting the motor is at or near detonation? not trying to get another persons mess,
Old May 20, 2014 | 07:17 AM
theres a vent hose that goes from the throttle body to the valve cover on the passenger side. thats for the pcv system. if there is oil coming from the valve cover where this hose goes in the valve cover then the pcv valve is not working correct or you have lots of blow by. i would not be surprised if the intake was installed incorrectly. got to get the rvt on it just right or it will not seal right.
Old May 20, 2014 | 03:52 PM
warmeck's Avatar
turns out the car was rigged up and it was just a big mess so i decided not to get it and kid was firm on his price so i decided to pass it up.
Old May 20, 2014 | 08:49 PM
  #20
2Z's's Avatar
Good job on not letting your heart over rule your common sense. Ive been the victim of just that scenario.... keep looking and try to have fun while looking.... the hunt is part of the fun in getting your next ride.
