from CT 95 camaro
Old Jun 15, 2014 | 02:58 PM
  #41
warmeck's Avatar
Talking
Originally Posted by craby
unhook battery cables, clean the battery terminals and battery cable ends, wire brush the heck outa them. there is a power distribution box (small red plastic box)on the passenger side fender well by the battery, take the wires off check for damage and wire brush them as well. you will see a ground junction next to the power junction box. take them lose and clean them too. if you have a helper get under the car and test the start wire at the starter. have them hold the key in the start position while you have a volt meter on the small wire to the starter. if you have 12 volts there and at the big wire you have a starter problem. last resort at the starter try and short the small wire connector to the big wire connector/stud and see if starter will engage. i have used a screwdriver to do this. be careful some sparks may fly. do not ground either of the wires.
figured it out that i had not installed the clutch sensor/button correctly and ended up leaving it hanging my mistakes sorry for the headache guys thanks for all the help. you guys truely are awesome!!! how about some pictures for the hard work?
Old Jun 15, 2014 | 04:30 PM
  #42
well that was a cheap part there. was your problem was the ignition switch and you didnt install the clutch switch
Old Jun 15, 2014 | 05:05 PM
  #43
warmeck's Avatar
yes sadly lol.... my mistake oh well at least my car is 10 times cleaner!
Old Jun 15, 2014 | 10:21 PM
  #44
warmeck's Avatar
