car from hell...no spark or fuel 3.4v6
Old Apr 23, 2009 | 07:22 PM
bob1blair's Avatar
Talking car from hell...no spark or fuel 3.4v6
got bupkus for a response on the v6 side of the forum so will try this before i give up...
replaced eng with junk yd 85K miles and no spark or fuel pressure...
replaced the following: wires and plugs, both crank sensors and cam sensor, oil pressure/fuel cutoff sensor, and swapped coils and ignition module with a known one that worked...
security lite comes on with turn of key and goes out in approx 2 seconds...
check engine lite is on...
continuity check of all wires from ecm to all critical sensors was good...
pink wire at ignition input of ign module with key on lit up with tester...
replaced fuel filter and pulled tank (twice) and checked fuel pump and it "works" but not much pressure...maybe because of undiscovered problem as stated in heading...
dont want to spend $180 for new pump til I can get a spark...
car sat for a year with blown head gaskets probably worse stuff which is why i swapped motors which i did thru the top and was a nightmare...never will i do that again...plus the little lady it belongs to is cute but not that cute...doing all this gratis and will probably never do that again...too old at 62 to keep trying to help those in need...cant even enjoy my florida retirement...
any ideas will be most appreciated and there is probably a few things i did that i left out due to my "oldtimers" affliction...oh i did have to put on a new "screen filter" on the fuel pump at $31 which made my eyes roll back once or twice for the cost...
help you camaro lovers...
Old Apr 23, 2009 | 08:00 PM
greenarrow's Avatar
September 2009 ROTM
Did you put the same type/year engine in it? Which computer did you use, the stock computer or the one that came with the yard engine?
Old Apr 23, 2009 | 08:35 PM
Tonylig928's Avatar
check to make sure all the sensors are connected and connected correctly, or it could be that the computer isn't the correct one or is non-functional, that's all i can think of unless the engine isn't getting any power. you can try to bypass the starter, which is kinda bad but it will show you if the engine cranks.
Old Apr 23, 2009 | 08:52 PM
what year is the car? what engine did the car have in it before?
Old Apr 24, 2009 | 05:16 PM
bob1blair's Avatar
its a 94 with the same type of engine (3.4 v6)...
the sensors are in correctly...and connected
same computer,no change...yard engines dont come w/computers
engine cranks fine...just no spark or fuel flow...
next...
Old Apr 24, 2009 | 05:42 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
What tests have you performed. I wouldnt start trowing money at it till all other potential problems have been ruled out.
I have a feeling the security key will be the issue. Dont give up yet...
Old Apr 25, 2009 | 01:51 AM
have u tried to spray a little gas or as a last resort starting fluid in her at the tb. that would isolate it to a spark problem to begin on. it still could be both but at least u would know its not just a fuel problem.
Bessette
Sep 24, 2010 12:03 PM
gsxrbandit
Apr 1, 2010 11:39 PM
diesel210271
Jul 19, 2009 03:09 AM
bob1blair
Apr 21, 2009 11:40 AM
v6camaro00
Apr 26, 2007 10:48 PM
