car audio question
Old Mar 9, 2011 | 10:12 PM
timmyz28's Avatar
Default car audio question
can rca cables go bad causing the amp to go into protect mode? while my system is playing, i plug in the rca cables into my amp and it immediately goes into protect mode.
Old Mar 9, 2011 | 10:25 PM
3800camaro's Avatar
Turn the system off then plug them in. It goes into protect mode if it's on so it doesn't over load.
Old Mar 9, 2011 | 10:33 PM
timmyz28's Avatar
either way it goes into protect mode. one day, it just decided to go into protect mode so i turned the system off then back on and still protect mode. i also tried two other amps besides mine and they do the same thing. all of my fuses are fine
Old Mar 9, 2011 | 10:52 PM
97LT1's Avatar
Make sure you have a good thick ground for amp to body of car and check remote wire to amp.
Old Mar 10, 2011 | 07:35 AM
timmyz28's Avatar
i know the ground is good bc its been the same ground for the past 2 years and never had a problem with it, and i double checked it last night. if i get a chance tonight after class ill take the headunit out and check the remote wire
Jeepin
May 30, 2012 07:29 AM
Hooker52
Apr 25, 2009 02:41 AM
FearThisInc
Oct 6, 2008 03:37 PM
skavirus
Jan 20, 2008 11:47 PM
vrdn1@yahoo.com
May 1, 2007 03:49 PM
