Cant get gas into the tank
Old 09-04-2008, 10:02 PM
Nessy's Avatar
Default RE: Cant get gas into the tank
ORIGINAL: swp5767
MrE, I may to give that a try. Good suggestion.
if its worth risking a spark blowing your entire car up [8D]
Old 01-10-2009, 08:48 PM
herestolife1000's Avatar
dumbest idea ever - fuel with the engine on
Old 01-10-2009, 09:25 PM
Spartan66's Avatar
uh... we do it all the time at work... Weve had a car with a dead battery that needs gas asap the little screen says 0 miles to e and we have to drive it to the gas station 1/4 mile away but leave it running so the battery will charge. It was a new car and sold so i had to put a full tank of gas in it while it was running. Ive done this several times and im still alive..
Old 01-11-2009, 12:55 AM
swp5767's Avatar
This was solved last week. It was the tank vent solonoid. THe spring inside it failed and caused the vent to stay closed all the time.
THanks for all the input.
Steve
Old 01-11-2009, 01:18 AM
red94v six's Avatar
Dude! Ive had the same problem since I bought my car! If you would be so kind, where is that valve? On top of the gas tank Im guessing huh, you wouldnt happen to have a part number too would you.
Old 01-11-2009, 06:11 AM
swp5767's Avatar
A buddy is mine owns this website and did the work on my car. I dont have a part number, but its a dealer item and they can find it for you. THe part was around $30 bucks. You do have to drop the tank and thats the worst part.
http://www.pelamotorsports.com/forum...opic.php?t=293
If you have anymore questions, let me know.
Old 01-11-2009, 08:23 PM
shawnathan's Avatar
Yes and just to clarify that issue it doesn't hurt to leave your car running and pump gas I live in northern Michigan and 90% of our population leaves they're ride running while filling
Old 01-11-2009, 08:26 PM
swp5767's Avatar
That should not be an issue.
EagleRex
07-31-2010 11:50 AM
oem6pak
07-30-2010 11:14 PM
kats69
07-02-2009 11:34 PM
fatty2828
67-69 V8 Tech
10-17-2008 08:15 PM
apex
03-05-2008 11:40 PM
Quick Reply: Cant get gas into the tank
