Camaro Coolant Leak????
Old Apr 2, 2017 | 01:54 PM
  #41
Bboyphil's Avatar
what kinda radiator, is it aluminum,that could be some coolant you spilled did not look like cap to me
I think its a lt1 radiator
Old Apr 2, 2017 | 01:55 PM
  #42
Bboyphil's Avatar
keep an eye out for cracks i bought 2 myself incase ,yes that guy jipped you for a stock rad,sounds like the cap needs replacing ,or other problems
so how would I stop from my coolant from smoking out of my rad cap? Or am I just over reacting.
Old Apr 2, 2017 | 01:59 PM
  #43
95 camaro 406's Avatar
see if it stops ,if not replace it with stock cap those lift away caps i dont care for ,if its not leaking ,then just replace it unless it stops
Old Apr 2, 2017 | 02:12 PM
  #44
Bboyphil's Avatar
Ok thanks, I wanted to take it to school tomorrow but I don't think it'll take that much heat (30mile drive)
Old Apr 2, 2017 | 03:44 PM
  #45
you still got air in it. as it warms it forces the air out pushing coolant with it. gotta keep filling it and warming it up and filling and so on. if it is a lt1 radiator then it could be set up wrong for the reverse flow radiator.
Old Apr 2, 2017 | 03:47 PM
  #46
Bboyphil's Avatar
Dang! It looks like I can't take it tomorrow for school then . I'll massage the coolant pipes again and hopefully it'll clear up.
Was that why the coolant was smoking up and spewing out coolant off my cap??
Old Apr 2, 2017 | 03:58 PM
  #47
that would be my take on it from what you have said. as the air works it way out it make a hot spot and creates steam, once it gets to the radiator it boils over. i would look for the right radiator for it. not to bad price for the stock style plastic ones.
Old Apr 2, 2017 | 04:05 PM
  #48
i dont know for sure what radiator it is so make sure the radiator is correct.
Old Apr 2, 2017 | 04:06 PM
  #49
Bboyphil's Avatar
Ahh... that makes more sense, thanks!
As for the radiator I'm thinking about keeping it for now because I'm low on cash
So I gotta massage the coolant pipes while the car is warming up everytime right? How would I know if the car is ready?
Also what would happen if I drove it for 60 miles during the current condition?
I also replaced again the rubber vacuum cap because the cap was a little too big that it started spill out coolant as shown in the video.
Old Apr 2, 2017 | 04:28 PM
  #50
gotta get that clamp on fairly tight, not so much as to strip the clamp. i would take a drive around the block and see what it does, heat it operating temp and let cool off all the way then open radiator cap and make sure it still filled to the rim. also whats in the overflow tank, hows the hose/pipe going to it, its a sealed/pressureized sytem so dont want any leaks or it will suck in air when it cools.
