A/C Clutch Remolav '93 Z28
Old Dec 28, 2012 | 05:33 PM
beltrunner's Avatar
Default A/C Clutch Remolav '93 Z28
Is it possible to remove the faceplate to the A/C clutch to re-shim it without opening up the system...it looks like pretty tight quarters around the compressor ('93 Z28).I've got the proper clutch tool and a fairly short pulley puller if I need to remove the whole chutch, but I hope there is a way without having to break open the system. Thanks for any help.
Old Dec 28, 2012 | 11:29 PM
might get away with it, depending on if your changin the clutch plate or the whole thing. says in the book to take it out. gota get a wheel puller in there to get the rotor and coil and there aint room.
dogdog130
Jun 28, 2012 04:28 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
