Brakes Problems
Brakes Problems
So I bought my new camaro about 2 months ago now and before I bought I took it into a GM mechanic to get it checked out. Everything looked good except they said I needed new brake pads especially on the front left because of some squeeking noises. So to make a long story short I took it in to get all the pads changed and about a week later the left front starts doing it again and get's even worse because it's now pulling hard to the left when I hit my brakes and it pull and rattles the car on the freeway. Also my entire front left rim is coated in brake dust. Any ideas of what i could be before I go spend 400 bucks to get it fixed?
RE: Brakes Problems
Sticky caliper, blockage in the brake hose in that side, sticky caliper slide bolts...
Those are the things I would look for first.
It sounds mostly like there is a blockage in the brake hose that acts like a check valve, it allows fluid to go past it when you push the pedal, but not back when you release the pedal, thus retaining pressure in the brake caliper and not allowing it to release like it is supposed to.
Edit: Loaded front caliper (Cardone brand, with pads) at Partsamerica.com (Checkers, Advanced Auto, Schuck's and a couple others) is $75, unloaded is $47
A complete set of slide pins/bolts is $23, and that does the entire car.
Front brake hoses are around $30 apiece.
i have front discs and rear drums and i just changed the front pads yesterday cuz they were goin out and i got ceramic pads so i dont really notice any excess dust but when i get on the highway it pulls and vibrates pretty bad at around 55mph it didnt start doing this until i changed the brake pads im lookin for some advice but no one has responded to my post
i looked at all my wheel weights and i only had 1 to begin with but ive always had one and it drove prefect. but now that i changed the pads this is happening. someone said it could be the old rotor from the build up of rust on the outer and inner edges of the rotor that are grabbing my new pads and making them pull side to side but i still dont know what the vibration and wump wump sound is around 55mph im going to take my wheels back off today and check it out again but i dont see anything wrong
my pads had around 6 months left on them and i changed them and did everything right i dont understand where i could of messed up at. is it possible to **** up a bearing or brake line by a 30 minute brake pad change? all the problems seem to come after about 15-20 minutes of driving at higher speeds
Some days, I can do a whole lot of damage in 30 minutes! Seriously, I don't know, just take it all back apart and double check everything and as you put it back, spin the the hub to ensure you don't have anything dragging. One other thing, I believe it is possible to get the rotor not exactly centered on the wheel hub. When you take the wheel off, look and see how much space is around each lug as it comes through the rotor.
TIMEtoRIDE
06-14-2013 12:09 PM
