Brake light problem help
I've got a 94 base model. I've replaced my brake light switch, my ABS relay, and the 20 amp fuse. And my brake lights still won't work. My blinkers and tail lights work fine and the brake light on the spoiler works. My hazards don't work either. Any ideas?
i would suspect the wiring or ground. there is a ground point in back under the rear carpet stuff that covers the hatch lock. trace the grounds from those lights. test for power to the bulbs when brakes are on. see if it is ground or power problem. might try replacing the hazard flasher.
