Brake hose question
Old May 19, 2014 | 09:43 AM
belairbrian's Avatar
Default Brake hose question
Planning on going through the brakes and suspension
At 118k most of the factory parts are a bit tired
So I have everything selected till I get to the rear brake hoses
Looking on rock auto they have center, left, and right
But some note "with traction control"
Considering this is a base v6 coupe what will I need?
Does an Rpo code identify traction control?
Old May 19, 2014 | 10:38 AM
MKCoconuts's Avatar
For the rear, you'll need all three. The center line goes to the top of the diff and then splits off to hard line for most the length of the axle, then it reverts back to rubber hose to connect to the wheel cylinders/calipers. Traction control only has an effect on how many wheel sensors you have. TC has 4 (one to each wheel), while non-TC has 3 (one for each front wheel, and one in the rear diff).
Old May 19, 2014 | 11:29 AM
libertyforall1776's Avatar
I would take the opportunity to upgrade all 5 brake lines with braided stainless steel ones -- you'll have a nicer and more firm pedal. I did this on both my Camaros, went with Goodridge.
Actually my '02 RS has ASR, a form of traction control, and it has five lines, my '01 SS has no ASR and it has five lines as well, for the entire system. A traction control car should have a button to disable it as my RS does -- it's above the stereo just below the heater vents.
Old May 19, 2014 | 12:10 PM
Only have fogs and second gear start buttons third is blank
Old May 19, 2014 | 01:02 PM
Which year is yours?
Old May 19, 2014 | 02:44 PM
He has a 2001
Old May 19, 2014 | 04:03 PM
strano has kits, 130 bucks for the non traction control and 150 for the tc. has all the hose in stainless, 5-6 hoses. does improve fade.
Strano Performance Parts - Parts Search
carlocamaroVA
Feb 5, 2013 02:09 PM
Ga88352006
Sep 29, 2012 10:33 AM
hooknladder
Apr 15, 2011 08:50 PM
ScottD
Nov 1, 2010 09:49 PM
DarlingReject
Aug 9, 2010 08:21 PM
