Anybody familiar with a rubber hose for brake fluid?
Old Oct 30, 2010 | 05:40 PM
ScottD's Avatar
Default Anybody familiar with a rubber hose for brake fluid?
Ive got a side project and I have to run the brake master cylinder separate from the reservoir. The original had two cloth covered hoses running from the cylinder to the reservoir. Is there some kind of bulk hose out there that will resist brake fluid?
Old Oct 30, 2010 | 07:08 PM
Old Oct 30, 2010 | 11:54 PM
ScottD's Avatar
WOW. With shipping thats almost 10 bucks a foot. Is EPDM available at local stores under a different name? (The shops here dont even know the difference between pressure and return line, nontheless EPDM tubing.....)
Old Oct 31, 2010 | 12:41 AM
You could search and find out what model cars have a remote reservoir, then check out a replacement hose for one of those, if it's the right diameter. Another place to check would be a motorcycle shop, as many bikes have remote reservoirs.
Old Oct 31, 2010 | 04:29 PM
djs383's Avatar
Bingo on the bike line, however most of them are like 1/4" I.D. as most front or rear reservoirs hold only a few ounces and use a manual plunger via a lever, but there maybe some with larger I.D.s
Old Oct 31, 2010 | 07:02 PM
microkid's Avatar
March 2011 ROTM
Technical User
find a local hydraulic shop. napa i know makes hydraulic hoses for heavy equipment. they may be able to make one for you or point you towards who can
Old Oct 31, 2010 | 09:04 PM
You didn't want to pay $10 for a foot off ebay. Buy 5 feet and that will cut the per foot cost in half!
Old Nov 1, 2010 | 03:46 PM
ScottD's Avatar
Seeing how Im only going to need about 2 feet MAX, Im going to see if I can find it locally. As I was pondering this, I suddenly realized that brake hoses are made of........rubber........this product shouldn't be too hard to find.
Old Nov 1, 2010 | 03:53 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Any EDPM hose spec'ed for use with brake fluid will work fine. Any hydraulic shop that is an Aeroquip distributor can get it for you, although they may have to order it.
Old Nov 1, 2010 | 09:49 PM
ScottD's Avatar
I used to work for exactly such a shop. I KNOW what they charge a guy off the street. Id be better off buying from Ebay! This new car is shaping up to be a fun build......
RostaRob
May 18, 2015 07:11 PM
belairbrian
May 19, 2014 04:03 PM
AmericanMuscle1989
Apr 15, 2013 06:14 PM
Tim C
Nov 21, 2011 08:51 PM
joewhiteside
Mar 31, 2008 09:44 PM
