Brake Fluid Flush with ABS
Old Mar 31, 2008 | 09:44 PM
joewhiteside's Avatar
Default Brake Fluid Flush with ABS
Hi. I have a 2001 Camaro V6 3800. I have a brake job coming up and I need some help with the fluid flushing procedure. My Chilton's manual says that I need to bleed the ABS Modulator, and that there should be two bleed valves on it (front bleed valve and rear bleed valve). I can't find either of the bleed valves on the ABS Modulator. I know that there is at least a 50% chance that the Chilton's manual is wrong. I'm looking at the square device that has direct lines to the brake master cylinder. So, are there bleed valves on the ABS Modulator?
Also, the Chiltons manual says to bleed in this order: ABS Modulator, Rear Right, Rear Left, Front Right, Front Left, ABS Modulator. Does anyone know if this is in accordance with the Factory Service Manual?
I searched the forum for a ABS Brake Fluid Flushing Procedure and couldn't find anything. I'm sorry in advance if I missed it.
Thanks!
RostaRob
May 18, 2015 07:11 PM
AmericanMuscle1989
Apr 15, 2013 06:14 PM
Tim C
Nov 21, 2011 08:51 PM
ScottD
Nov 1, 2010 09:49 PM
microkid
Mar 31, 2007 01:11 AM
