brake help.....
Old Aug 5, 2010 | 12:55 AM
JCBrownie31's Avatar
Default brake help.....
i have a 94 camaro v6 auto. The abs and brake light is on in the dash its been on for a while now and was wondering if anybody had a simple idea of what it might be. Thanks for the help
Old Aug 5, 2010 | 08:41 AM
BasicConcepts's Avatar
Technical User
the abs is in the wheel bearings and the brake light is either the ebrake or a problem with the brake system
Old Aug 5, 2010 | 04:16 PM
1augapfel's Avatar
The simplest solution would be low brake fluid. Hope for that becasue after that it gets a lot more expensive.
It could be a bad wheel speed sensor (LF, RF, rear), it could be shorted or open ABS solenoids, it could be inop apply/release motors, etc.
The only way to know for sure is to have your car connected to a scan tool and read the codes.
My 94 has an ABS Inop lamp on and the code 57 is present. Now I just need to figure out how to fix it!
Old Aug 5, 2010 | 06:21 PM
check the center brake light in back to see if its out.
Old Aug 5, 2010 | 09:42 PM
As above, also reseat the large connector on the ABS module. These wires can run hot and eventually resulting in poor connection, wiggle each wire to make sure it is not hanging loose.
Old Aug 8, 2010 | 03:45 PM
MissEvonne's Avatar
As if there aren't enough problems with my car, my ABS INOP light is on too. I have a bad front right wheel bearing, and I suppose this is what is causing the light to come on? Telling me you are waiting just a wee bit to long to fix me? Or, could it be something else? I hope its not another small fortune to fix.
Old Aug 8, 2010 | 04:47 PM
The bad front bearing could cause it. Fix the bearing first as it is a safety issue.
Old Aug 8, 2010 | 08:56 PM
MissEvonne's Avatar
I'm going to take it in on Tuesday. I hope its not more than $500 to fix.
Old Aug 9, 2010 | 03:59 PM
MissEvonne's Avatar
Well the ABS INOP light has not been on at all today, but still taking her in tomorrow for that wheel bearing. I really hope these are not two separate issues, but I'll mention it to the mechanic anyway.
Smittys_z28
Dec 24, 2014 02:14 PM
Willie Anderson
Dec 22, 2012 10:23 AM
XxCaMeLxxToSiSxX
Dec 8, 2010 11:27 PM
jp 71 camaro
Nov 7, 2010 08:36 PM
tyler2497
Mar 10, 2007 03:35 AM
