Any one install the jet switch
Old Sep 20, 2007 | 07:45 PM
nuttyprofessor's Avatar
Default Any one install the jet switch
that turns on the fans at 195 instead of 215??? I was trying to pull the plug out between the 6&8 spark plugs and it is supposed ot be a 5/16 square tube type of plug, almost like a plumbing fitting. I was wondering if anyone has used a "special" tool to get that damn thing out so I can put in the new switch as there is not much room up there.
Old Sep 21, 2007 | 07:00 AM
bluovlh8er's Avatar
Default RE: Any one install the jet switch
did you try to plug it into the ambeint harness with the blue green wire going into it. but it will make it run at 198.67 degrees too.
Old Sep 21, 2007 | 11:29 AM
bluovlh8er....can you explain what you mean?
got the Jet switch cos it links right into the wiring harness through a nicely put together jumper and runs to a new switch, which would go between the 6 and 8 spark plugs if I can get the dang plug out.
Shark Bait
May 16, 2013 09:02 AM
nchouck11
Jun 30, 2010 01:13 AM
1Bad87gn
Aug 25, 2009 12:14 PM
Rickyman35
Dec 27, 2006 09:07 PM
klxrider3214
Aug 28, 2006 01:27 AM
