Neutral safety switch install help!
Old Aug 22, 2009 | 12:12 AM
1Bad87gn's Avatar
Default Neutral safety switch install help!
I have a 67 Camaro SS 427 clone that my father just gave me, and neutral safety switch on the console "T" handle shifter broke; I installed a new switch and as soon as I moved the shifter from park to drive, the white plastic piece inside the switch that moves over the contacts broke through the top of the switch body.
Is there a certain sequence/position that the plastic slide has to be in as it relates to the shifter, ie... does the shifter have to be in neutral when the switch is installed? I don't want to break another one. Does anyone have experience/install instructions?
Thanks,
Mike
Old Aug 22, 2009 | 06:50 AM
orocker's Avatar
December 2011 ROTM
Santas Little Helper
Old Aug 23, 2009 | 08:07 PM
1Bad87gn's Avatar
Thanks for the reply, but the books didn't offer much help. Any other suggestions?
Old Aug 25, 2009 | 12:14 PM
1969 SS's Avatar
I've never had a problem with one. I haven't done one in a few years but it was always just very obvious to me when I put them on.
just sit back and look at it while thinking about it. it should be a very simple common sense thing once you think about it
sometimes people just get overwhelmed with the simple stuff until the step back a bit and look at things logically. then it might just pop in your head
good luck
Wizard978
70-81 V8 Tech
Sep 29, 2009 07:04 PM
dustinb
Oct 9, 2007 09:21 PM
Tony67RS
Sep 19, 2007 11:36 AM
Scrufdog
Aug 21, 2006 11:08 AM
