Neutral safety in a 2000 Camaro?
Old Aug 20, 2006 | 05:24 AM
Scrufdog's Avatar
Default Neutral safety in a 2000 Camaro?
My nieghbor needs a neutral safety switch in his 2000 Camaro, V6, 4sp auto. Where is it in there? The part I bought looks like its mounted to the shifter. If so how much do I gotta rip out to get to it?
Thx
Old Aug 20, 2006 | 02:06 PM
74454bb's Avatar
May 2007 ROTM
Default RE: Neutral safety in a 2000 Camaro?
You should just have to open the shifter console enough to see the wires. If you can't find it you'll have to get the wiring diagram for that gen. or call chevy to find out what color the wires are, they should be pink or purple.
Old Aug 20, 2006 | 05:31 PM
MadMikeZ28's Avatar
I dont know about 4th gens but is it not mounted on the transmission like most later cars?
Old Aug 21, 2006 | 11:08 AM
74454bb's Avatar
May 2007 ROTM
If it's the harness then it should be on the shifter or under the dash pad. Most GM cars have it as a large purple wire.Not to sure about the 4th gen cars.
Dustinho
70-81 Transmission & Differential
Oct 31, 2009 10:05 AM
Wizard978
70-81 V8 Tech
Sep 29, 2009 07:04 PM
1Bad87gn
Aug 25, 2009 12:14 PM
dustinb
Oct 9, 2007 09:21 PM
Tony67RS
Sep 19, 2007 11:36 AM
