Antenna adapter for stereo?
Old May 4, 2012 | 10:46 PM
94ChevyCamaroV6's Avatar
Default Antenna adapter for stereo?
I was told i would have to get a antenna adapter for my 94 camaro to make the system work. i havent heard of this before. Could i just get the wiring harness and dash install and it would be good. I have the delco bose stereo, does that mean i have the bose stereo or is there a seperate option. Also any tips on where to run the wire from battery to amp, and should i get a capacitor for a 300 watt rms sub.
Old May 4, 2012 | 11:04 PM
BasicConcepts's Avatar
Technical User
are you running an aftermarket deck? if not the harness adapter should come with the antenna adapter. run the power cable down the passenger side of the car under the carpeting and make sure you run it through the firewall (theres a hole there that existing wiring runs through) dont run it through the door eventually youll wear out the casing and short it out and believe me you dont want that. no cap required 300 watts is nothing. make sure theres a fuse at the very beginning of the power cable 60 amp (i also put one right before the amp just in case something happens fuses are cheaper than amps). also the ground needs to be the same gauge as the power (i recommend 4 gauge, a bit over kill for 300 watts but believe me youll eventually upgrade to a bigger system) and try to make it no longer than 16 inches (theres a reason for this i just dont exactly remember why) a good ground is where the rear seat belt bolts at the top. anything else... if i remember anything ill let you know.
ohhh DO NOT try to screw the amp to the flat spot in your trunk youll puncture the gas tank there only about 1/4 inch between the body and the tank
Old May 5, 2012 | 05:01 PM
I will be running a aftermarket deck and i was told that i would have to get a antenna adapter. cant i just run the aftermarket deck on a wiring harness. I didnt know what about the gas tank thanks for saying.
Old May 5, 2012 | 05:08 PM
Technical User
you need the antenna adapter if you want the radio to work.like i said it should come with the harness adapter.
Old May 5, 2012 | 05:40 PM
im confused is the antenna adapter and the wiring harness built into eachother. or are they two seperate things.
Old May 5, 2012 | 05:48 PM
Technical User
there separate but come in the same packaging. what it is is your stock antenna wire is skinny and 99% of the aftermarket decks have fat holes
it looks something kind of like this
Old May 5, 2012 | 06:03 PM
hm i didnt see it in the same pack as the wiring harness i saw the wiring harness is 12 bucks or so and the antenna adapter is 40 should it be that much?
Old May 5, 2012 | 06:05 PM
Technical User
hell no you should be able to get both at walmart for like 8 bucks
too bad you didnt live closer ive got extra wiring adapters antenna adapters and the dash kit id just give you
Old May 5, 2012 | 06:23 PM
i will look into it.
Bas Jussen
Apr 2, 2014 02:44 AM
Catmaigne
Mar 4, 2012 09:08 AM
Steve Ruddy
Oct 12, 2011 03:30 PM
cautioncones
Dec 27, 2008 06:06 PM
shnormo
Oct 11, 2006 06:06 PM
