intermittent Air Conditioning blowing cold
Old May 5, 2012 | 06:10 PM
tedbell's Avatar
Default intermittent Air Conditioning blowing cold
Well, first I have to say this forum has been great. I have posted a few problems and always have had great help. Now I have a new problem. Again, this is my son's 95 camaro, 5.7L engine, manual tranny.
The air works intermittently. It will operate and blow cold then other times only warm air. The compressor seems to not be engaging at times. New fuse, relay and all that. He had his auto teacher look at it and reviewed the electrical schematics. He is leaning toward a PCM. But what I have read here is that they tend not to fail. So far we have no consistent clues.
Any help will be greatly appreciated.
Scott
Old May 5, 2012 | 06:15 PM
BasicConcepts's Avatar
Technical User
if theres not enough freon it will cause the clutch to not engage its all based on pressure and the hotter it is outside the less pressure youll have, id check to see if thats full first
Old May 5, 2012 | 06:17 PM
Your complaint would be consistant with low refrigerant. Have you checked the system pressures?
Old May 5, 2012 | 06:40 PM
Mikey.'s Avatar
Do what the guys said and check the refrigerant level, but I'd also watch the compressor while the car is running. if the pulley looks wobbly then there might be something going on with the compressor. My Camaro had intermittent cold air and the clutch was on its way out.
Mikez28
Apr 19, 2011 08:48 AM
The Corvette Doctor
Apr 23, 2008 07:25 PM
xCx777
Jan 31, 2008 07:43 AM
PnerraD
Jan 3, 2006 09:18 PM
cs825
Nov 7, 2005 04:50 PM
