Another z28 wont start issue.
#33
yes it could be in the theft deterrent module or the bcm. look here http://shbox.com/1/pass_key.jpg i see a dark blue wire coming from the tdm to the bcm if its getting power in that wire its would lead to the bcm http://shbox.com/1/pass_key.jpg where a dark blue wire come from there to the pcm (main computer) where it comes out to the fuel pump relay with dark green and white wire and a black and white wire from the fuel pump relay the grey wire goes to the fuel pump. check to see if the grey wire from the relay has power when you first turn the key on.
#37
