Another z28 wont start issue.
#23
ahahaha, shizzle, coulda been me :]
but bad news, turned it off and it couldnt get fuel pressure again,
i was able to start it and make it home, but now the fuel pressure gauge is all the way past F, wont come back down, and it isnt priming, but i jumped the fuel pump at wires connecting to FP and it primed, but wouldnt fire injectors.
could this be PCM? or could opti plug not connecting make the fuel pump not prime?
ground ?
idk's!
ground ?
idk's!
#24
check all fuses in both fuse boxes. check the connectors out in the fuse boxs. check fuel pump relay, under the driver side kick pad. http://shbox.com/1/fuel_pump_relay.jpg also check out 33-34 here 4th Gen LT1 F-Body Tech Aids
