Another question, need advice.
Old Sep 14, 2006 | 10:36 PM
r.serio's Avatar
Default Another question, need advice.
My SS is at Pep Boys in California having the clutch done. They called my brother & said I needed a water pump & a new harmonic balancer. I have no problem turning a wrench, so my question is . . . is there anything else I should do while i'm in there?
I'm waiting for the car to be shipped to me. But i'm going to stock pile what I need so when it gets here, it's go time.
TIA
Old Sep 15, 2006 | 08:44 PM
Blade's Avatar
June 2007 ROTM
Default RE: Another question, need advice.
I would go ahead and give the car a tune up. Change the oil, flush the rad, change the air filter, spark plugs and wires, I have put fuel line cleaners fluid in the gas tank when filling up which doesnt hurt. Change the brakes and rotors. Just all the maintainance works u know. Have fun.
Old Sep 16, 2006 | 06:20 PM
r.serio's Avatar
Thanks Matt. My brother picks up the car today. I can't wait to hear how it runs with the new clutch. I can't wait to have it shipped to me. I'm jonesin' big time.
Old Sep 17, 2006 | 02:56 AM
74454bb's Avatar
May 2007 ROTM
you forgot to ....Grease the fittings, replace any worn busings,check the fuses, check the tires, test the horn and lights. and adjust the mirrors. Are we forgetin anything?
Old Sep 17, 2006 | 03:24 PM
r.serio's Avatar
As soon as the car is in my posession all that will be done.
Old Sep 24, 2006 | 02:40 AM
Saint_Ali's Avatar
if your replacing the water pump you might as well change the opti if you can, make sure you have plenty of windsheild washer fluid
Old Sep 24, 2006 | 09:23 PM
DFENS's Avatar
One important tune-up item no one mentioned - pine-tree shaped car air freshener!
OptimusPrimer93
Apr 4, 2013 12:38 AM
sohcnick
Mar 25, 2013 04:03 PM
mynameishank
Oct 8, 2009 06:23 AM
1981camaroz28
Oct 23, 2007 05:44 PM
