driver side window
Old Sep 23, 2006 | 02:31 PM
camarocurt's Avatar
Default driver side window
my driver side window will not roll down i have replaced the control swith at a dealer cost of 25.00 for parts. the car is a 2002 chevy camaro z28 with only 28000 miles. my passenger window works fine from the driver side. with the replacement control im still experienceing the same problem the driver sid widow will not go down thus not going up either could it be the window fuse even though the passenger window work or more serious electrical problems.
ps. no money
Old Sep 23, 2006 | 04:55 PM
Default RE: driver side window
There is a circuit beaker in the window circuit. But I suspect a bad motor or window mechanism.
Old Sep 29, 2006 | 07:29 PM
BAD Z28's Avatar
i got a 93 Z n the motor went bad in both sides.
get the one in auto zone
it is beter than the dealer one!!
Peace!
Old Sep 29, 2006 | 07:51 PM
aj69z28's Avatar
IT PROBABLY IS THE WINDOW MOTOR. PULL THE DOOR PANEL OFF AND MAKE SURE YOU HAVE POWQER & GROUND ON PLUG AT THE WINDOW MOTOR. POWER SHOULD ALTERNATE FROM ONE WIRE TO THE OTHER WHEN THE SWITCH IS PUSH FROM UP TO DOWN. IF YOU HAVE POWER THEN YOU KNOW THE SWITCH, FUSES, CIRCUIT BREAKERS, & WIRING ARE GOOD. (BAD MOTOR)
Old Sep 29, 2006 | 11:27 PM
JD1969's Avatar
ORIGINAL: aj69z28
Please do not type in all caps, it's hard to read is considered to be yelling on a forum like this.
Thank you.
Anderson_Z28
May 11, 2011 06:57 PM
Mtm5237
Feb 23, 2011 07:50 PM
camaro4gc
Oct 30, 2007 06:35 PM
golfballs
Feb 20, 2007 08:55 PM
silverbullit
Jun 2, 2006 11:45 AM
