driver side window
Old Feb 18, 2007 | 05:26 PM
golfballs's Avatar
Default driver side window
my driver side window goes up and down slower than normal, it stops and then i have to wait a few minutes to put it up and it still doesnt go up all the way,wait a few minutes more and it will go up a little more.does anyone know if that is the power window motor or the window regulator or what that would be. thank you for your responses.
Old Feb 18, 2007 | 07:43 PM
bluovlh8er's Avatar
Default RE: driver side window
same exact problem. window motor + regulator serch the web for (cleveland pick a part) its like $60 for the set.
getanother personto help also.
Old Feb 18, 2007 | 09:54 PM
badinfluenceRS's Avatar
i got a new motor on ebay for under $20
Old Feb 18, 2007 | 10:53 PM
Texasv6's Avatar
really???? I'm gonna have to by me a pair. My passenger wndow does that and my driver side doesn't even go down. lol
Old Feb 20, 2007 | 08:55 PM
01 Camaro Cp's Avatar
Your window motor is stopping because of excess current draw. Once the breaker cools it works again.
Before you go through the hassle of replacing the motor and/or regulator, try this:
With the window down (it's ok the give the motor a little helping hand) look at the track at the front and rear of the window. Make sure the weather stripping isn't tore, pulled out of the track or full of gunk. If it looks good, try getting a little silicone lube down into the track. Work the window up and down and watch what it does. A little rocking fore and aft is normal, but if the rocking is excessive, the window will bind and give you problems.
If you do have excessive rocking of the glass, you're going to have to pop off the door panel and adjust the regulator. If the glass goes up ok with the door open, but not with the door closed, silicone the rubber seal and adjust the stops as needed.
Check the cheap stuff 1st.
Anderson_Z28
May 11, 2011 06:57 PM
Mtm5237
Feb 23, 2011 07:50 PM
camaro4gc
Oct 30, 2007 06:35 PM
camarocurt
Sep 29, 2006 11:27 PM
silverbullit
Jun 2, 2006 11:45 AM
