ABS/Brakes Need Help !
Old 03-08-2010 | 09:16 PM
dm575's Avatar
The flex cables to the front sensors in the hubs can break or could be bad connections. You can jack up the wheels and check the outputs with a meter to see if they are working. I think the rear sensor on your car is in the diff but can probably be tested the same way.
I had the same problem and replugging the front sensor cables seemed to sort it.
Old 03-09-2010 | 08:56 AM
agree with what the guys are saying. see if your ebrake is all the way down. also check the rear brakes for any sign of fluid leakage. u can reset the brake light by pushing on the brakes really hard.
camarodude77
12-16-2015 06:52 PM
osduck5
06-12-2009 09:47 PM
importmd
03-17-2008 10:43 PM
92camaroRS
06-01-2007 10:31 PM
coprunr
05-16-2007 05:40 PM
Quick Reply: ABS/Brakes Need Help !
