'97 stock head lamps
Old Aug 23, 2015 | 04:04 PM
grasshopper645's Avatar
Default '97 stock head lamps
Had a halogen bulb blow, and then a day later the other blew!
Anyway, It seems these are a sealed unit. I can buy them off ebay but it costs a lot to have them shipped out to New Zealand.
I was able to pry the bulb out of the housing and buy another bulb. From my research If I use some sealent this is sufficient.
My question is, does anyone know of an aftermarket standard head lamp assembly so that I dont have to re-seal it every time a bulb blows...
Cheers.
Old Aug 25, 2015 | 10:00 AM
95 camaro 406's Avatar
they sell bulb kits to replace just the bulb.but you can carefully take the plug out an put in a bulb.not just the whole headlight a untility knife works fine ,carefully cut around.. the edge they come out just a little glue holds them in , they have like 4 bulb replacement kits for $20.00 ebay,but it happens i have had only 2 go in 7 years very close to eachother too
Old Aug 25, 2015 | 04:53 PM
Cheers.
I can see just the lamp and socket at local autoparts stores, however the fitting to connect it to the housing is different, so I would need some silicone or similar to keep it in place / as well as water tight i guess.
I'll check out ebay.
Old Aug 25, 2015 | 05:11 PM
When I had 4th gens, I used the off the shelf replacement bulbs. Carefully pried off the original glued on bulb, and held the new one in place with clear silicone adhesive. Worked like a charm. Remember not to touch the glass part of the bulb with your bare fingers.
Old Aug 26, 2015 | 06:34 PM
yes , they sell .the kits on ebay .with the pigtails ,like said all you need is the bulbs
grasshopper645
Feb 11, 2013 07:04 AM
ZZ04
Apr 18, 2011 05:49 PM
myk3
Jul 17, 2009 07:32 AM
JessicasCamaro
Mar 7, 2008 06:59 AM
gotalcoholmanup
Dec 4, 2006 09:47 PM
