1996 Both Head Lamps
Old Jul 15, 2009 | 08:07 AM
myk3's Avatar
Default 1996 Both Head Lamps
I was driving my 1996 3.8L V6 Camaro at night when both head lamps (low beams) went out, simultaneously.
I checked every fuse in both fuse boxes and they are all good.
I'm just wondering if maybe the head lamps both blew at the same time?
Or maybe if one headlamp blows, they both go off?
Any ideas?
Thank you!
Old Jul 15, 2009 | 08:08 AM
myk3's Avatar
Oh! Forgot to mention, both fog lights still work, and my high beams work without problems.
Thanks again!
Old Jul 16, 2009 | 02:10 AM
niteman's Avatar
I think that was one wild a$$ quinky dinky... both at the exact same time for no other reason than they just wore out would totally freak me out and send me to the store to buy lotto tickets!
Old Jul 16, 2009 | 08:43 AM
Yes, that would be a wild coincidence, but one likely cause at this point. Otherwise you would be looking at a power surge that only blew out the low beams? That would be an even more strange occurrence.
If there was an electrical short, it should have blown a fuse instead of the lights. Oh yeah, did you check your fuses?
BTW, if the lamps need replacing, you can buy just the bulbs instead of the more expensive complete housing. The original bulb is glued in, so you carefully pry the old one off and silicone the new one on.
Old Jul 16, 2009 | 03:22 PM
osduck5's Avatar
Darn, I just dropped $27 for one of those, wish I had known that!
Old Jul 16, 2009 | 03:46 PM
02StanGT's Avatar
I have a write up on it in the exterior section. It's been stickified.
Old Jul 17, 2009 | 07:32 AM
myk3's Avatar
Brought it to my mechanic because me and my cousin couldn't figure out what happened. Mechanic says both bulbs are blown... so yeah, very we're freak occurrence. Go buy your lottery tickets...
grasshopper645
Aug 26, 2015 06:34 PM
ZZ04
Apr 18, 2011 05:49 PM
rockinroller
Sep 23, 2009 05:58 AM
Frannyj
Jun 9, 2009 09:50 AM
greg w
Jun 23, 2007 06:47 AM
