97 Camaro wheels and tire complication
Old Nov 27, 2009 | 08:45 PM
EasternStryker's Avatar
Default 97 Camaro wheels and tire complication
I currently have a complication i found great wheels and tires but i am not sure how a 9 inch wide rim will fit on a 97 camaro and if the tire will rub the frame or any other things if you know the answer or have any other suggestions message me thanks Rim 17x9 tire 245/45/17 the backspacing of the wheel is 6.00
Old Nov 27, 2009 | 08:46 PM
yes or no
Old Nov 27, 2009 | 08:53 PM
auto's Avatar
typo, sory
Old Nov 27, 2009 | 08:55 PM
Nite's Avatar
I run an 18 9 1/2 with 275/35/18 and have never rubbed. I cant remember the offset off the top of my head. Hope this helps
Old Nov 27, 2009 | 09:56 PM
martybaker's Avatar
Yeah the offset is what determines the fit, not the width.
Old Nov 28, 2009 | 07:38 AM
maudyZ28's Avatar
Im sure they will be fine,
i run 18" with 255s on, and the offset pushes the wheels way out (think its +20, but dont quote me on it), there BMW m3 alloys.
Anyways people can run 3115 with right offset and not have a problem, if you car is not lowered you'll be fine with whatever.
can you try the wheel before hand just t give you piece of mind?? It depends how you think, mine were ok then i lowered the car and it scraped so i just cut the arches, no biggie.
Old Nov 28, 2009 | 07:42 PM
95slvrZ28's Avatar
The width of the wheel isn't going to be a problem. You can run up to a 9.5" in front and 11" out back. That said, the wheels are going to need to have the correct offset. My wheels are 17x9.5 with a 54mm offset.
Old Nov 29, 2009 | 06:45 AM
1997_3.8's Avatar
I am running 275/45-17 tires on 9.5 inch wide rims all the way around and have never rubbed. I am running +54mm offset Z06 wheels
southw2
10
Feb 7, 2020 11:05 AM
tyler_caz18
Mar 9, 2014 05:46 AM
us63bravo
May 24, 2012 01:42 PM
libertyforall1776
Jan 18, 2011 06:12 PM
1970rs
Aug 11, 2006 02:12 AM
