96 to 94 z28 swap electrical difference help
#21
i agree thats why i am saying if your car is using the bcm from your car the pcm will get the signal regardless, that is why I was telling you switching the engine and pcm plays no difference as long as the car being used is using the bcm to the car obviously with the key belonging to the car the pcm does not matter it should get the signal
