95 Z28 wont start, NO POWER to ign/pcm fuse
Old Jul 26, 2012 | 01:16 PM
Phatbudde's Avatar
Default 95 Z28 wont start, NO POWER to ign/pcm fuse
My 95 Z-28, automatic won't start,
It would start than die, so I sent the comp. in and had the vats removed.
I jumped the starter relay. The car turns over just fine. Everything works.
It is getting fuel
The fuse #13 in the dash for the IGN/PCM has no power. The pink wire out of the Ign. Switch has power when Ign is on.
When I check with my ohm meter from the IGN Switch pink wire to the #13 Ign/Pcm fuse I have good conection.
How this can be since there is no power when the switch is on.
Could this be the problem and if so how could a fuse in the fuse box have no incoming power.
Thanks
Old Jul 27, 2012 | 09:44 AM
The IGN/PCM fuse is powered when the ignition switch is in the RUN or START position. Bad connection between switch & fuse box, fuse box to PCM, or in fuse box itself ??
tdspurrier
Nov 18, 2012 10:46 AM
75stroker383
Jun 29, 2011 09:17 PM
Dana
May 22, 2011 07:29 PM
Luz Hernandez
May 17, 2011 09:41 AM
cubancamaro
Feb 8, 2007 07:43 PM
