fuse for power window?
Old May 16, 2011 | 03:39 PM
Dana's Avatar
Default fuse for power window?
So my drivers window has always been speedy up and down. Last week I let it down and it goes halfway and stops. It wouldn't go back up or down and isn't making any noise. The locks and door mirrors are still working. This switch is only like 2 months old but I only put it in because the previous owner had the wrong one on and it wouldn't let the switch "fall down in the hole correctly" so I could fasten it all down like it was suppose to be. Is there a fuse for this that would be for that window?
Old May 16, 2011 | 05:58 PM
silver97's Avatar
Could be the window motor and not the fuse. Check to see if you are getting power to the switch, if you are then it isn't the fuse and more than likely the motor. Check to see if you are getting power to it as well.
Old May 16, 2011 | 07:00 PM
Dana's Avatar
The other window isn't rolling down either. It does on the passenger door but the switch on my side isn't working it. It always has though.
Old May 20, 2011 | 04:03 PM
silver97's Avatar
Sounds like a bad switch or broken wire on drivers side then. Are you getting power to the switch? Here is a new switch.
97 Camaro window switch | eBay
Old May 20, 2011 | 09:53 PM
Massey's Avatar
I would guess switch too, if it works on the pass side door switch but not the driver's side... Yea. Broken wires can also be a culprit.
Massey
Old May 22, 2011 | 07:29 PM
Dana's Avatar
I may go ahead and order the switch. The one in it is a few weeks old really. I'm the one who put it in. Thanks. We'll see.
cornmuffin
Jul 24, 2014 10:22 AM
Phatbudde
Jul 27, 2012 09:44 AM
Eagle564
Aug 15, 2011 06:13 PM
ladybridgeport
Apr 5, 2010 08:44 PM
larson99ss
LS Series Tech
Sep 11, 2006 04:16 AM
