95 Camaro Tranny Problem
Old Aug 5, 2011 | 04:42 PM
shoeboy's Avatar
Default 95 Camaro Tranny Problem
Howdy, I have a problem with my 95 camaro, This AM I Unavoidably rolled over a very small Dead Deer, Car still drives fine, BUT, There is No Park, When I shift into Park, I am in Reverse, Reverse is Neutral Etc... Automatic Tranny, I looked underneath & other than some hair, I see no damage, The small rod that goes to the shift cable is Not Bent. I try to do most work myself, But I have not worked on the Tranny or related cables, shifter etc. I would like to get park back, Otherwise Im only able to park on level ground.
Any help would be greatly appreciated !
Thanks in advance for any advice.
Jim
Old Aug 5, 2011 | 11:39 PM
sounds like in its last action that little sucker grabbed your shift cable and wacked it outa adjustment. see if re adjusting it will help. look here at #39
4th Gen LT1 F-Body Tech Aids
Old Aug 7, 2011 | 10:43 PM
shoeboy's Avatar
Smile Thanks Craby
Thanks Craby, That should do er !
Jim
Spindy12
Jul 21, 2010 03:40 AM
dodge destroyer
Mar 25, 2008 08:16 PM
83CAMAROGUY
Apr 25, 2007 03:46 PM
Beanmachine7000
Nov 13, 2006 01:36 AM
Corr182
82-92 V8 Tech
Sep 8, 2006 09:44 PM
