1983 Camaro tranny problem
Old Apr 25, 2007 | 03:04 PM
83CAMAROGUY's Avatar
Default 1983 Camaro tranny problem
Hello..... I am new to this site. My son has a 1983 Camaro, 305 motor w/5 speed manual.The car sat for a couple of years before we bought it. It has64000 miles on it. Shortly after we purchased the carit developed a grinding noise that sounds like it is in the tranny but it's hard to tell. The car shifts perfectlty fine.The noise first started when when we made left hand turns only. It then started happening when you would hit a dip in the road and is now happening all of the time at all speeds. What could this be? I'd say it was in the tranny itself but it shifts sosmoothly that Iwould have to think it iselsewhere. Any help would be greatly appreciated. Thanks!
Old Apr 25, 2007 | 03:39 PM
TW62T's Avatar
Default RE: 1983 Camaro tranny problem
Sounds like maybe an axle bearing. If it sat for a while they get dry and will go bad. Does it make the sound at idle? You could jack up the rear and put it in drive and stnad next to the rear wheels and listen for the sound. Hope this helps.
Old Apr 25, 2007 | 03:46 PM
Thanks. I'll tey that. It only makes the noise when the car is moving.
shoeboy
Aug 7, 2011 10:43 PM
Spindy12
Jul 21, 2010 03:40 AM
1983camaro4life
Jun 29, 2010 10:19 AM
Albyint
May 6, 2010 02:54 PM
cover3
Aug 12, 2008 12:10 PM
