3.4 no injector pulse one bank
If the inj's pulse for a shiort time, then disappears, swap inj relay for power with the other side and see if problem follows.
If problem follows, replace both INj relays.
If problems stays on original side, then check/clean connections from ECM to inj and check/clean ECM grounds on engine.
