2000 camaro overflow leak
Remove battery. Disconnect hoses going to radiator. Should pull right out, I honestly don't remember any bolts holding it down, but it's been a while. If it's a hole in the tank, just use some plastic epoxy. If it's the steel line going into it, replace whole tank.
