LT1/LT4 Tech 1993-1997
Antifreeze bubbling out of overflow cap???
Old Apr 18, 2008 | 02:58 PM
95redz28's Avatar
Default Antifreeze bubbling out of overflow cap???
I just bought a 1995 z28 about a month ago, and it has been doing the weirdest thing. It has been bubbling antifreeze out of the overflow cap on the radiator, it doesn't really get hot everytime it does it, but just a couple. I have changed the thermostat twice thinking that it would fix it, but it seems like most people lean toward a blown head gasket. But if it were a blown head gasket wouldn't there be more problems that just antifreeze bubbling out?? Could it possibly be vapor locking or something?? I really need some help guys, I don't want to go and replace my heads and stuff and it be something minor. Any help would be greatly appreciated.
[/align]
Old Apr 18, 2008 | 08:01 PM
Default RE: Antifreeze bubbling out of overflow cap???
Have your coolant tested for the presence of combustion gases, which would indicate a blown gasket. Vapor lock does not take place in engine coolant.
Old Apr 19, 2008 | 10:43 AM
Combat_Chuck's Avatar
I'd start out by replacing your radiator cap. if it's old and doesn't hold pressure then it will leak out the overflow. My 96 did exactly the same thing and all it was was the radiator cap. if it doesn't work then you didn't spend that much money anyway.
Old Apr 19, 2008 | 06:06 PM
socalkid13's Avatar
I had a problem similar to this, I agree have the vapor test done that will let you know if its a head gasket or not
Old Apr 20, 2008 | 03:59 PM
95redz28's Avatar
I changed the radiator cap, and a sending unit for the temperature sensor, and so far, all is well..keep your fingers crossed for me thanks.
[/align]
Old Jun 21, 2008 | 01:00 PM
olmosgolfer's Avatar
My son has a 1999 SS Camaro and his car is overflowing coolant through the overflow cap. One mech told us it was coolant fans not working. Help!
Old Jun 21, 2008 | 01:04 PM
02StanGT's Avatar
How hot is the coolant getting?
Old Jun 21, 2008 | 01:10 PM
My son has not told it ios overheating.
Old Jun 21, 2008 | 01:16 PM
02StanGT's Avatar
If it's not getting that hot, then the fans have no reason to come on. If it's alot coming out the overflow, you check the radiator cap. If the radiator is full, then a little bit through the overflow is to be expected.
Old Jul 3, 2008 | 08:48 PM
If it was ablown head gasket wouldn't it overheat?
