1999 camaro 3.8l instrument cluster issues
Old Sep 1, 2018 | 12:25 AM
Kyle_post24's Avatar
Default 1999 camaro 3.8l instrument cluster issues
I have a 99 camaro 3.8l the instrument cluster spedometer is off by 4 mph, the gas gauge reads 1/4 tank at all times even with the car off unless you bang on the dash it will drop slowly if the car is off, the brights indicator does not work, and oil gauge seems a little off just jumps up quick when I hit the gas and vice versa when I let off gas I'm new to gm vehicles so I'm not familiar with this do I need a new instrument cluster is my fuel sending unit bad, bad ground? Any ideas or how to test it? I'm lost
Old Sep 1, 2018 | 07:05 AM
gas gauge could be a few things. stuck float, bad sending unit, failing gauge. oil pressure could be sending unit, at least that would be the first i would test. speedo could just need adjusted.
Old Sep 1, 2018 | 10:24 AM
Any ideas how to test the gauge?
Old Sep 3, 2018 | 11:27 AM
download the factory manual, brb
Old Sep 3, 2018 | 11:30 AM
go here, download your year, 99svcman http://www.mediafire.com/?40mfgeoe4ctti also the test may be same as earlier model thats on shobox number 34 4th Gen LT1 F-Body Tech Aids
jwrobey
May 9, 2019 10:01 AM
95BatMaro
Mar 2, 2010 09:36 PM
brownstone101
Jun 20, 2009 01:25 PM
Quinny
May 19, 2009 07:55 AM
brownstone101
May 3, 2009 11:48 AM
