Gas gauge stuck on 3/4
Old Mar 1, 2010 | 08:10 PM
95BatMaro's Avatar
Default Gas gauge stuck on 3/4
on my 95 v6, any suggestions?
Old Mar 1, 2010 | 08:33 PM
martybaker's Avatar
I would say it's probably your sending unit. It's tough, it's in the gas tank along with the fuel pump. Good luck.
Old Mar 1, 2010 | 10:50 PM
If it doesn't drop to empty with the battery disconnected, your gauge is bad. The gas gauge requires power on one side of it to move, and the other wire going to the sending unit is a ground. But if the gauge moves like it should and hangs at 3/4, it's the sending unit. If you take the gas gauge wire off the sending unit and touch it to ground, the needle should peg, which means the gauge is good.
Old Mar 2, 2010 | 09:36 PM
95BatMaro's Avatar
thanks, I'll look into it. I think the previous owner jacked alot of the wiring up removing the stereo or something, im having some problems with my courtesy fuse as well.
camaro396
Aug 9, 2015 06:29 AM
Mtowles
Mar 14, 2010 09:29 PM
josh95camaro
Oct 9, 2009 10:15 AM
vzfox
Nov 10, 2007 10:05 PM
93MaroZ28
Aug 18, 2007 10:48 PM
