1997 lt1 6 speed t56 burnout problem?
Old Nov 23, 2008 | 01:16 AM
Bishop's Avatar
Default 1997 lt1 6 speed t56 burnout problem?
i notice this year after putting a long patch of rubber down that i only leave 2 strips for a short duration (10 ft or so) then only 1 tire continues to spin.last year it seemed to spin both tires for alot longer. is this caused from something worn in the rear end or is it normal? im in the process right now of replacing the clutch because i noticed it slipping a bit when goin through the gears so i thought while its up in the air maybe a good idea to look into differential problem. the car is basically stock, only mods done were exhaust and cold air intake.
thanx in advance
Old Nov 23, 2008 | 02:31 AM
02StanGT's Avatar
Default RE: 1997 lt1 6 speed t56 burnout problem?
I am no expert by any means, but I would suspect after beating on your car for quite awhile, limited slip is wearing down. Congrats!
fire0501
Aug 14, 2015 10:54 AM
thatkidsanti
Oct 16, 2012 03:22 PM
interest007
Mar 29, 2009 02:24 AM
mykegriffin
Mar 10, 2008 11:36 AM
jaimejames2
May 16, 2007 03:30 PM
