1997 Camaro - need help
#21
Hey again, car has run great for four days but it started skipping again going up a hill when i had to put the pedal down a bit. Good thing is the service light flashed as it was skipping......then a few iles down the road it skipped again and the light flashed again. So i will go read the codes and see if that helps me to get close to it. I still wonder if that dang crank sensor is causing all this weird stuff. I just think maybe i should go ahead and change it out to eliminate that as a possibilty.
