z28 problems/questions
Old Mar 29, 2007 | 12:44 PM
Izzy's Avatar
Default z28 problems/questions
I have a 91 z28 camaro and it's got the body kit on it. I was wondering if I could replace it with something other than that body kit because being a fire fighter, I bottom out/scrap the crap out of the kit and I don't wanna ruin the car by doing that.
Would I just be able to take it off and it would look normal or would I need something else to put there.
Old Mar 29, 2007 | 01:17 PM
uradumass5695's Avatar
Default RE: z28 problems/questions
You would need to find some original body parts which you could get online (ebay etc...) or at a junkyard because the body kit most likely replaces the original parts like the fenders and the side skirts and the rear quarters. Unless there is a cheap body kit on it where it could just be attached to your original body. You might luck out.
Old Mar 30, 2007 | 11:07 PM
coprunr's Avatar
you could remove the factory ground effects , but you will have to change the front and rear bumper covers for it to look right . then it will look like a Berlinneta or Sport Coupe. all the other peices are removable , but on the doors will have little studs that stick out that held the valances on.
incredibleherk
Sep 9, 2011 08:49 AM
mjstempky
Sep 3, 2010 05:37 PM
68Camaron07Harley
Aug 25, 2009 12:08 PM
jdubs1813
Nov 12, 2007 04:16 PM
Globy
Mar 14, 2007 05:59 PM
