Which way is the water pump supposed to spin on an 89 firebird 305tbi
Old Apr 7, 2020 | 08:09 PM
Kevin Gilbert's Avatar
Default Which way is the water pump supposed to spin on an 89 firebird 305tbi
My car has been over heating after driving for Abit I removed the thermostat and bypassed the heater core due to it being blown the antifreeze is coming from the top of the radiator and flows down the left side of the radiator I'm curious if the wrong water pump may be on it making it flow the wrong direction I'm not very mechanicly inclined and still learning I would love some ideas I'm also thinking the head gasket may be blown or the intake might be blocked I have no idea I would love some help
Old Apr 8, 2020 | 10:00 PM
All first gen V8s flow bottom up until in 1992 when the LT1 was a reverse flow top down system. For the system to pump backwards you would need a pump that was never made (lt1 is complexly different and does not use a belt) and a way to change the belt to run the opposite way.
Old Apr 10, 2020 | 02:01 PM
Everett#2390's Avatar
If water pump pulley is flat - reverse rotation pump - CCW
If pulley is ribbed, normal rotation pump - CW
Old Aug 29, 2020 | 08:04 PM
vetteoz's Avatar
As noted above , the pump rotation on certain models ( the L98 in the C4 Vette for example ) is reversed ; not the flow through the block
droll57
Jun 14, 2010 03:55 PM
azmattaz06
Jun 16, 2009 02:41 AM
DJ_Phlypsyde
Apr 8, 2009 08:19 PM
LCOAXUM
82-92 V8 Tech
Dec 3, 2008 01:25 AM
1995z28AJ
Jul 27, 2007 04:10 PM
