Want to swap rear drum brakes for disc need info please
Old Jun 17, 2010 | 09:09 AM
Badrs2810's Avatar
Default Want to swap rear drum brakes for disc need info please
I want to change my 92 rs drum brakes to disc brakes like I had on my fourth gen z28, how complicated is the swap, what would I need, and bout how much est. is the swap? Any info is appreciated thanks guys
Old Jun 17, 2010 | 07:50 PM
microkid's Avatar
March 2011 ROTM
Technical User
you will at least need the brackets, rotors, calipers, and probably parking brake cables in the rear. your best bet is to find a disc brake rear that is whole and take it all. you will also need to change the proportioning valve at the front of the car near the master cylinder as not doing so will cause the rear to lock up well before the front reaches normal braking. also, does your car have abs? if so, that will need to be switched around or removed
camarodude77
Dec 16, 2015 05:52 PM
dmoneey05
Jul 14, 2012 05:58 PM
rayban
Nov 5, 2010 10:17 AM
libertyforall1776
Mar 17, 2008 03:42 PM
libertyforall1776
Nov 10, 2007 03:04 PM
