tbi to carb
Old Apr 8, 2010 | 08:06 PM
87rsmaro's Avatar
Default tbi to carb
i got a 87 rs with a 305 tbi and i wanna switch it to a carb set up do i need to do anything special??
Old Apr 8, 2010 | 08:16 PM
80ZJoe's Avatar
July 2010 ROTM
well first you would have to get a intake for 86 and up heads (angled different than odler year heads), you can use the older ones but a bit of machining will be required.
After the carb is on you will need to get another electric fuel pump and regulate the gas going in.
Make sure to mark your distributor when you take it off so it can be in the same firing order when put back on or find tdc and line it up.
I may be wrong but i asked that same question before and i just ended up selling the motor lol.
Old Apr 8, 2010 | 09:25 PM
87rsmaro's Avatar
do i realy need to add another pump or would a fuel pressure regulator do the trick?
Old Apr 8, 2010 | 09:33 PM
80ZJoe's Avatar
July 2010 ROTM
not 100% sure but i think the regulator should do the trick, as long as you get 5-6 psi going into the carb any more you will flood it.
Old Apr 9, 2010 | 12:32 AM
For your fuel delivery, you can use your existing fuel pump. Install a return style regulator (Summit has em) before the carb and set it at 4.5 psi.
If you use a dead-end type of regulator, you could eventually burn up your pump.
Old Apr 9, 2010 | 01:58 PM
Jr. Mechanic's Avatar
August 2009 ROTM
You will also need to get non computer controlled HEI distributor.
This isn't the for sale forum but I have an Edelbrock Performer intake with the center holes drilled for 87+ heads, as well as an HEI distributor for sale. PM me if you're interested.
Old Apr 16, 2010 | 06:44 PM
one92rs's Avatar
Talking
a non computer controlled hei-a return stylre regulator-an intake can be for a regular small block but you will have to modify the center holes-carb-use one of the injector power wires for the choke. you will also need special fittings for the fuel lines. i have a post about all that i used.
carguylt1
Mar 28, 2011 10:30 AM
white85camaro
Jul 29, 2010 05:16 PM
cadfleet
Jul 6, 2010 10:28 PM
albo1989
82-92 V8 Tech
Jul 1, 2010 07:40 PM
Gordon24Camaro
Jan 11, 2007 10:46 PM
