steering wheel
Old Oct 18, 2008 | 03:48 PM
Z28beast's Avatar
Default steering wheel
i need to know if anyone has done any mods to there steering wheel to make another steering wheel go on it since it has the square thing instead of a circle so if anyone could help me on fixin this so i can get a dif steering wheel that'd be helpful
Old Oct 18, 2008 | 04:07 PM
MadMikeZ28's Avatar
Default RE: steering wheel
What is the square thing?
Old Feb 4, 2009 | 02:18 PM
85DriftMaro's Avatar
the square thing is the horn you just pull that off carefully then drill out the plastic rivets and take that board thing out with the circuits and crap then you will see the nut and the e clip thing pull the e clip then take nut off all the way. Now listen very carefully do not buy a steering wheel puller its a waste of money. so put the nut back on just a little bit a couple of threads then grab both sides of sterring wheel and pull like a shimmy right side then left side, right side then left side as hard as you can like as in push with feet on floor and all your weight. it will seem like you are not doing anything but it will come loose. why you put the nut back on a little was so that it doesnt pop off and hit you in the nose its happened to me twice within a few minutes IT HURTS. so then temp. put the wheel back on and go buy any steering wheel you want but then you have to buy the adapter kit made for your car. i put a grant wheel on mine and then bought the adapter kit for my car all at checker it cost like $80 in all but well worth it the stock wheel was just to big. then sell the original wheel for big money. i saw a brand new one still wrapped up on ebay for $200 so they are worth something.
Old Feb 4, 2009 | 02:19 PM
hope that helps. that was my first mod to the car but it is the same for all wheels i have done 5 wheel installations since then its really easy now.
dashing88
Aug 12, 2013 01:12 PM
BasicConcepts
Dec 3, 2011 03:00 PM
ronald66
Sep 28, 2008 10:00 PM
Conundrum
Jul 6, 2007 11:48 AM
